question about steering knuckle when replacing brake pads - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2008, 01:34 PM
pigjamelectric's Avatar
oldsmobile compatible
Last wiki edit: Selling your car Last photo:
Wiki Edits: 29
I am in the middle of replacing my front brake pads. I noticed that the two knuckle surfaces upon which the outside pad hardware rides was corroded and pitted (See pic). I took a file to it to clean it up.
My question: What kind of lubricant, if any, could or should I put on there to keep the surface smooth and to protect it from corroding? Or is that a forbidden area for lube considering how close it is to the braking surface?
Name:	steering knuckle.jpg
Old 09-14-2008, 02:03 PM
Wiki Edits: 29
I just noticed my pads came with brake lubricant for these contact surfaces. I did some more research anyways and it looks like I'll be able to answer my own question. I'll post a good site I found for the record.
http://www.aa1car.com/library/2005/ic80560.htm
The important thing this site points out about what I was wondering is that petroleum based products can't handle the heat that brakes put out. It could liquify and contaminate braking surfaces.
Silicone-based brake lube is the way to go.
62 Nova Steering box Question. ElguapoShoebox Suspension - Brakes - Steering 15 12-21-2010 06:03 PM
Steering rack installation question Rons1stRod Suspension - Brakes - Steering 7 11-07-2007 08:52 PM
Power steering whine/lack of assist question '45 Ford Suspension - Brakes - Steering 7 07-05-2007 02:05 PM
34 Chevy underfloor brake install question? hutcholdschool Suspension - Brakes - Steering 7 01-18-2006 09:25 PM
Brake Reservoir Question Jag Daddy Suspension - Brakes - Steering 3 03-31-2003 10:47 AM
