question about tire size - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2006, 03:49 AM
I have a 70 model camaro,and I'm needing to know what would be a good tire size for it, the rims are 17", the rear suspension is pretty much stock,hasn't been narrowed it has a 496 big block so traction is a plus any one have any ideas would help alot thanks for looking dboyett if anyone has pics postem if you would
Old 11-25-2006, 10:47 AM
LordMaximo's Avatar
Last journal entry: Painting
First off, why in the world are you putting non-standard sized rims on your camaro? If you actually wanted to have a cool ride, you should have done some studing on the dynamics of tire size. Larger tires/rimms, means more work on the braking system. Youor standard size was either a 14" or 15" rim and with a set of "70 series" tires on your ride, you could as much as a 265 high speed multi rated radial for your car. But now you want to put on some ******** DONK rims for something that is not designed for this application.
First, you should have measured the actual tire height of your standard application. Next you will need to subtract the actual size of the rim you are changing out to. Then you have the height of the tire size you need to keep the same height of the standard size.
Your suspension was not designed to run 17" rims on the camaro. You will need to make the neccessary brake changes for the larger rims. Plus your turning radius is now 4" less from corner to corner due to this change.
Good luck.
Old 11-25-2006, 01:22 PM
poncho62's Avatar
Wiki Edits: 5
It's called Hotrodding...................
Even though, I am not a fan of these larger rims, I cant see how they would affect anything. These 17 in rims usually use a lower profile tire which will make the outside diameter of the tire the same as a 14 or 15 in tire/wheel combo.
Maybe I am wrong about all this....enlighten me.
I think he is asking what width will fit under there. I know a quite wide tire will fit under these cars. My concern with all this would be.............496 Big Block, stock rearend plus wide tires..........equals.......breakage
Old 11-25-2006, 01:50 PM
powerrodsmike's Avatar
Wiki Edits: 161
Lord Maximo, nice words of encouragement. With some research, you would find tires that are the same overall size, just have larger rim sizes. Sometimes you need bigger rims to fit bigger brakes. That is why we are putting 18" wheels on our 68 Chrysler Imperial project. With 29" tall tires. SAME overall diameter as stock. What does the car care what the rim size is? The od of the tire is what matters.
You are right poncho
Here is a link to a spiffy chart that helped me understand the bigger sizes. http://victorylibrary.com/mopar/car-tire.htm
I doubt is some of the tires on that chart actually exist, so you need to go find a tire company you like and.......
Go to that tire companies website and get to the pages that have actual tire sizes in section width and overall diameter and suggested rim width, it makes selecting a tire easier.
Here is a sample page from toyo tires, of the sizes available for only ONE of their tread patterns.
http://www.toyo.com/docs/tires/produ...category=sport
not my favorite company, but indicititive of the resources that are available by looking on line. I just went to the website, picked a tread that looked cool , selected "sizes and specs" .
Most of the manufacturers have pages similar to that one.
Get your pencil and paper ready, especially if you want to find bigs and littles in matching treads.
Have fun,
Mikey
Here is one more thing to consider when choosing to go with the larger rims, , a larger rim may keep you legal when you start modifying your suspension to make your car lower as the increased rim diameter will raise the scrub line.
BE different....ACT normal.
Old 11-25-2006, 03:24 PM
Protowrxs's Avatar
Last journal entry: 69 Stang - C&L Pipe - Electric Fan
Another handy site I found a link to is this dynamic version. Plug in the info and get a view of what the tire would basically look like on different rims. Along with this and a coupe pieces of cardboard I've measured enough to get a good idea of what I can run. Helps to figure out those milimeter wheel offsets as well.
http://www.rims-n-tires.com/rt_specs...=mysize&text2=
-Stephen
Old 11-25-2006, 03:53 PM
Good luck.
I put 24 inch rims on all types of cars everyday and with some work you can make anything work.A 17 inch alum, rim is not going to change a hole lot so u do some studying there vette rims i dont want mine to be like everyone else's with drag lite or centerline rims and it will look alot better,and i have seen vettes run low 9s with the same type rims with drag radials.turning radius is not going to be cut 4 inches either
Old 11-25-2006, 04:13 PM
poncho62's Avatar
Wiki Edits: 5
So............You're the one...................That's almost as big a crime as the one that OJ guy committed.......................I said "almost"
Old 11-25-2006, 07:51 PM
i never said i was,but that is what i do for a living the majority suspension work. i really didn't want a pissin contest. I have posted alot and you are the first i know everything type and everybody else are just rookies Ive come across. i just wanted a good size for this car i have one in mind all-ready,but there is alot of people who have been there and done that thats why i ask thanks for all the good replies thats why i love this site if u keep it stock u cant call it custom dboyett
tire size paintrep32 General Rodding Tech 3 04-02-2006 11:21 PM
Camaro Tire Question ugly stupid impotent Hotrodding Basics 5 01-16-2006 04:42 PM
what tire size should I use TheCiscoKid General Rodding Tech 2 01-05-2006 08:36 PM
Wheel and wide whitewall tire size help DK23 General Rodding Tech 3 09-03-2004 08:04 PM
tire size mini tubbed 73 duster tad Suspension - Brakes - Steering 2 09-11-2003 03:20 PM
