Question about torqueing balancer bolts. - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-19-2008, 08:05 AM
Hello guys I have a few questions about certain bolts to torque. I have a 350 chevy and I use a tci rattler balancer on it and on one site it says to torque the balancer bolt to 60 foot pounds but on my tci rattler instructions it says 70 foot pounds. Haynes manual says between 70 and 90 but to check your manual for correct specs. What should I do it at 60 or 70ftlb? Also should I use some locite on it and my pulley bolts? And while I am thinking of it on my timing cover should I put gasket maker on my timing cover bolts so oil does not have a chance to come out the bolt threads? Thanks a bunch guys you have been a great help. Take care.
Eric
Old 06-19-2008, 08:21 AM
Guy Hiltz's Avatar
I would go by what TCI says and torque to 70 ft.lbs.And I use Loctite on the balancer & pulley bolts,you dont these to come flying off.As for your timing cover,I just use some Ultra Copper gasket maker on it with no gasket,this seems to work fine.
Guy
Harmonic balancer size question. Big vs. small johnbelanger Engine 3 02-15-2008 11:19 AM
Torqueing the Balancer DrBee8457 Engine 2 12-28-2007 12:21 AM
BBC balancer question r3dart Engine 4 12-16-2007 07:25 PM
Harmonic Balancer Question pi71 Engine 7 07-15-2007 01:28 AM
sbc balancer question STATUTORY GRAPE Engine 8 07-11-2005 05:59 PM
