Question about touching up Base Coat/Clear Coat - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-08-2011, 02:57 PM
Hi,
I am new to this forum and have found a lot of great information. I need to ask the painters out there a question. I am repainting my 1967 Triumph TR4A myself and am using a base coat/ Clear Coat finish. I am currently doing the underside of the hood using LIMCO 123 Base and a GT Select Clear Coat. This is a low cost base $35.00/quart paint. I am planning on using a higher grade paint for the outer surfaces to help with UV protection but that is down the pike..
My question is that I had sprayed the base over a gray primer and after spraying the clear (trying not to stick my #$#$ finger in it!!) I noticed a couple of spots that I didn't get good coverage and would like to respray.
Do I have to wetsand the area first or if I respray withing 24 hours can I just mix up some base and touch it up?
Thanks in advance.
Base coat/clear coat urethane over acrylic enamel mervhudson Body - Exterior 5 04-23-2011 10:56 AM
Couple of base coat/clear coat questions bigbrowndog Body - Exterior 17 11-05-2010 08:37 AM
Acrylic Enamel vs. Base Coat Clear Coat 70chevy Body - Exterior 175 11-11-2009 02:07 PM
Base coat clear coat repair problem TimeBandit Body - Exterior 2 09-03-2008 06:22 PM
laquer primer/ppg base coat/clear coat? dave mc Body - Exterior 5 10-11-2005 04:59 AM
