Question about wires? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-29-2012, 05:43 AM
I am using Accel Hi-Temp Super Stockcopper core 7mm wires and I am finding when I ohmed them out that from one end to the other end I am getting no ohms but a dead short, is this normal?
Old 08-29-2012, 06:02 AM
67Mustang Al.'s Avatar
Stealth 316 - Wire Resistance and Voltage Drop Calculator
This chart will answer your question.
Al.
The Following User Says Thank You to 67Mustang Al. For This Useful Post:
raguza123 (08-29-2012)
Old 08-29-2012, 06:14 AM
These are ignition wires not wires, vehicle wiring. Would it fall under the same as far as resistance?
Old 08-29-2012, 06:58 AM
Thanks Al, I just got off the phone with Accel, the tech claims that the copper core will not ohm out except that it will give me continuity only and that these ignition wires are ment for a points ingition system, I should be using carbon core wires.\, with my Pertronix ignitor system
Old 08-29-2012, 07:32 AM
Hi there
Copper leads or copper wire, same applies.
Yeah the chart will give you very small readings for copper so if you know the diameter of the copper or AWG ( American Wire Gauge) it will give you fractions of an ohm, not much. From that chart 18 AWG copper has 21 ohms/ km so for a plug lead being 500mm long for example you would only have a fraction of an ohm or next to nothing showing on a standard workshop meter.
I guess if you have the wrong leads there is always ebay
Al
Old 08-29-2012, 08:06 AM
I understand that when I went from a points ignition to electronic conversion, I needed to up grade my wires too, as the copper/nickel core which are like a 18 ga. wire would be better for points , an Accel tech said the performance would be better with carbon core wires.
There is very little resisitance with these wires, I'm running a Pertronix Ignitor Conversion kit with an Accel super stock coil(canister style) and a ballast resistor of 1.85 ohms
Old 08-29-2012, 11:01 AM
If you run low impediance copper wires, you may want to run a single spiral core (or resistance core) wire from the coil to the distributor. This was the warning on my Mallory HyFire System, and is what I did.
The Following User Says Thank You to toddalin For This Useful Post:
Old 08-29-2012, 01:44 PM
I decided to replaced the set and put this set away should I decide to return to a points ignition system, I'll go with the type I used before I went to the solid core. it always ran good with them.
Old 08-30-2012, 07:07 AM
I did find a set, they had only one type Accel Super Stock radio suspression core, I know how much you all don't like Accel, I just found out they aren't made here, they were made in my home town back in the day when Echlin owned them.
Anyway new readings:
Coil lead 5,500
#1 31"long 11,000
#2 36"long 16,000
#3 31"long 9,000
#4 36"long 11,000
#5 26"long 9,000
#6 27"long 9,000
#7 23"long 8,500
#8 27"long 10,000
Are these Ok readings one I a little leary about #2 a little high
Old 08-30-2012, 07:31 AM
You have a variation there for sure in your long leads but i dont think you will notice any difference between the two when they are installed. If you had a result like your copper readings then i would be concerned .
Al.
raguza123 (08-30-2012)
Old 08-30-2012, 07:42 AM
Al.
Could be my cheapo meter?
It's analog not digital
Old 08-31-2012, 09:12 PM
Analog VOM resistance readings are sensitive to the condition of the batteries in your meter, and whether its zeroed properly before you start.
Based on your measurements I don't think you have any bad wires, but only the manufacturer of the wires can tell you the normal range.
Bruce
The Following User Says Thank You to 75gmck25 For This Useful Post:
raguza123 (08-31-2012)
Old 08-31-2012, 09:37 PM
Thanks for the reply, I tested the engine out with the wires and it does run much better tahn it did with the copper core I had on there.
1964 impala hei resistance wires question solo20 Electrical 29 05-22-2011 02:10 PM
ACCEL spark plug wires Question greenmoonshine Electrical 1 01-23-2009 09:30 AM
Really Dumb Question about wires to HEI rac43 Engine 4 11-27-2006 08:07 PM
Points and plug wires question western star Engine 3 08-08-2004 10:01 PM
Quick Question About Spark Plug Wires 1967stang Engine 1 10-02-2003 07:09 PM
