question again :) - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-27-2013, 04:15 PM
the youngone
Last journal entry: progressthe
question again :)
hello guys .
i still have somthing what im not sure about,
when engine is cold and i start it. after a short ride the coolanthose on top is already hard. engine temp is afther 5 minutes about 60 degree celious. when i take it for al long trip. and i let of the pressure with the radiator cap and drive another 15 minutes. thers almost no pressure in the system. ? so when cold.. presure and with warm engine and lose the pressure its soft.
thnx
Old 05-28-2013, 01:38 PM
the youngone
anyone who can help
Old 05-28-2013, 03:15 PM
techinspector1's Avatar
Wiki Edits: 326
I'm not real sure what you're saying, but one thing you can do that will not cost any more than a thermostat gasket, is to remove the thermostat housing and make certain that the thermostat is not installed backward. It's easy to install it wrong, I've done it myself. The little "pill" or copper heat-sensing element must be toward the motor, down inside the manifold.
Old 05-28-2013, 03:20 PM
the youngone
It is down i placet myselve . I was deep thinking about my problem and i think there must be pressure in the system. Becouse the waterpump is pumping . The reason why the. Pressure is ghone while i open the. Radarorcap is i think becoux there is. Going. Coolant in the. Expansion tank.. So there is a little les of coolant in the system so less pressure. .. Is that. Right?
Old 05-30-2013, 10:56 AM
the youngone
Helpp
Someone? Can help?
Old 05-30-2013, 11:13 AM
evolvo's Avatar
What is the relief pressure of your radiator cap? Are you saying that you are opening the cap while the engine is still at operating temperature and relieving pressure? Do you then re-install the cap and drive or are you driving with the cap off or loose?
What kind of engine is this? Is it possible you have a reverse rotation water pump?
Need lots more information but we can figure this out!
Wezz, your english is a little hard to understand, but it's still way better then my Dutch!!
Old 05-30-2013, 11:17 AM
the youngone
Haha. Ok im do reinstal the cap. Its a. New waterpump for my engine a 305 .. I gues the pressure is. Ghone becouse there is less of coolant
Old 05-30-2013, 02:22 PM
Banned
you get the correct water pump.. v belts turn one way, serp belt pump turns the other.. wrong pump will pump a tiny bit. but not enough
700R4 Corvette Servo question, (pin question) Guntar13 Transmission - Rearend 3 11-10-2011 12:05 AM
sbc timing question and carb question.....i am ready to absorb your knowledge c_cham Engine 16 02-12-2011 11:26 AM
Timing question and cylinder head question.. Blackhauk90 Engine 2 05-22-2007 01:10 PM
Transmission question and rear end question demitristewart Transmission - Rearend 1 09-14-2005 07:38 AM
not a rod question but an engine swap question for a daily driver.. DeathByGreaser Hotrodders' Lounge 2 01-22-2004 10:59 PM
