Question for all chevy 41-46 1/2 truck owners - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2005, 07:31 PM
badriand's Avatar
Curious as to what you did for mounting the bed to frame? Did you use original type wood blocks or go with some square tubing or something?
Thanks in advance.
Old 09-16-2005, 11:38 PM
Chevy mounted the bed like that all the way up until 54 I believe. I used the wood blocks on my 48.
Old 09-20-2005, 07:21 AM
badriand's Avatar
thanks martinsr, are the blocks like 2" by 2" or something? Was wondering if it would be better to use some tubing or something so you can forget about the wood roting any?
Old 09-20-2005, 08:28 AM
I don't remember how big they are. I think I just mounted the bed and figured out how high they had to be to make the bed fit properly.
Old 09-20-2005, 10:45 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Make your blocks out of Oak as well as that wood does not crush when you apply torque to the bed mounts..also works under cab mounts in those old guys..
OMT
94 chevy truck maybe dist./ignition problem,please help! bluesmanjesse Engine 14 11-19-2004 03:31 PM
stearing,suspension,upgrade 1946 chevy truck jamie boyster Suspension - Brakes - Steering 2 10-06-2004 09:27 AM
46 chevy 1\2 ton truck windsheild regulator parts? machmn Interior 2 10-05-2004 09:50 AM
A newbie question about my Chevy truck BigRed Engine 10 01-01-2003 01:24 PM
66 ford truck swapping a 240 i6 out for small block chevy igotachevyor2 Engine 0 04-14-2002 03:19 PM
