80 grit is perfect.
Use the Turbo as it was made for the restro and rod builders. Everything else sounds good but with the last coat being a 50/50 mix you will need to use MS or HS none of the others will work with that system. Barry I reread. Change the following. Since your going to let the single stage set, don't come back with 50/50/. Do this. Spray enough color unmixed with clear to cover 1coat maybe two than last coat with 50/50 mix. Than wet-sand and shoot one to two coats of clear by itself. We do this a lot and makes for a lot of work but a look that is unmatched for show. |
| Hotrodders Guidelines -- READ ME | Jon | Hotrodders' Lounge | 0 | 06-14-2003 05:08 PM |
| Hotrodders Guidelines -- READ ME | Jon | Body - Exterior | 0 | 06-14-2003 05:00 PM |
| Hotrodders Guidelines -- READ ME | Jon | Interior | 0 | 06-14-2003 04:59 PM |
| Hotrodders Guidelines -- READ ME | Jon | Transmission - Rearend | 0 | 06-14-2003 04:58 PM |
