Question for barry K - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2005, 06:44 PM
62galaxiguy's Avatar
Hi barry SPI products are great i got a ? for you Ive got a 77 vette in the shop for a friend shot it w spi epoxy gray id like to shoot a poly primer over it(YOU KNOW THOSE WAVY VETTE BODIES) can you suggest one?Ive used feather fill before but i cant seem to find it anymore. thanks mike
Old 04-30-2005, 01:59 PM
roger1's Avatar
Mike,
I just used Evercoat Slick Sand polyester primer on my '69 Vette. I really like it. It sprays on smoother than Evercoat's Feather Fill yet still is very high build. I used 180 grit dry on a sanding board and it flattened out real nice. I am going to finish it off with Evercoat Uro-Fill urethane before spraying the SS urethane paint.
Roger
Old 04-30-2005, 02:43 PM
rusty428cj's Avatar
I also use Slick Sand and it works great need a spray gun with a 2.3 tip. I spray 2 coats block with 80 spray 2 more coats block with 180. Use SPI black epoxy first so you can see high and low spots. It was not a Corvette but a fiberglass Shelby hood and deck lid.
Old 04-30-2005, 03:22 PM
roger1's Avatar
I used a cheapo spray gun from Harbor Freight with a 2.0 tip.
However, I do mix in a touch of acetone to thin it down just a little.
Works great.
Old 04-30-2005, 07:17 PM
BarryK's Avatar
I like the slick sand and the U-Pol but not to long ago a jobber gave me a quart of Debeers polyester to try and it reminded me of the old original Spies polyester.
I really like the debeers but have no idea the cost and is sure its more than the slick sand. They all work pretty good.
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hotrodders Guidelines -- READ ME Jon Interior 0 06-14-2003 04:59 PM
Hotrodders Guidelines -- READ ME Jon Transmission - Rearend 0 06-14-2003 04:58 PM
Hotrodders Guidelines -- READ ME Jon General Rodding Tech 0 06-14-2003 04:57 PM
Hotrodders Guidelines -- READ ME Jon Engine 0 06-14-2003 04:53 PM
