As a minimum, I'd coat the terminals liberally with grease/spray for battery terminals or even just Vaseline. You should also get rubber terminal covers, which are sold for various applications (marine use is probably the easiest to find).
Another consideration might be protecting the battery from physical damage. If the wheels throw water up on it, they might also throw gravel and road debris. Bruce |
Install an Optima or other jel battery. These are corrosion free and will last a long time. With one of these batteries, if you are concerned with the terminals corroding, then enclose them with a liberal coat of silicone.
Trees |
Battery
I have a 46 Chevy Pickup and installed the battery on the frame rail behind the rt ft wheel. It gets everything the wheel throws @ it and I have had no problems since 2004. I use the truck almost everyday. Good Luck
