Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Question on blow by on a fresh build
Old 04-18-2011, 09:36 AM
Ignitrous Ignitrous is offline
So initial start up and a few days of driving i never had this much smoke. I took it out to the track and fouled some plugs and had to limp the car home. After replacing the plugs and fixing a leak on the intake manifold im blowing smoke like crazy. If i pull the breather it looks like a steam train, installed a pcv hoping that would help, no such luck. After it warms up a bit there's oil that starts bubbling out of the breather.
Did i mess up the rings? Even if i try to start the car and let it run for 5 seconds and shut it off theres smoke that continues to pour out of the breather for minutes afterward. Should i just tear the motor back down?
