Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - question on bolsters
Old 11-04-2009, 05:03 PM
Mr. HMP Mr. HMP is offline
do you think glue will hold well enough to the foam. what glue would you use.
I was wondering if a backing was required so that when the cover is stretched in place, the sides of the bolster won't move. the 1" foam would then be stuffed into the pocket creating the bolster.
I have 2" on the frame already. maybe I'm making more out of this than required.
