you need to build up the foam on the frame and shape your foam the way you want your bolster to look...and figure out where your going to put ur listing (depending on what kind of seat it is) for hog rigs or if your going to glue the cover on...once youve built your foam to how you want it then you can make your bolster patterns out for making the cover...
do you think glue will hold well enough to the foam. what glue would you use.
I was wondering if a backing was required so that when the cover is stretched in place, the sides of the bolster won't move. the 1" foam would then be stuffed into the pocket creating the bolster. I have 2" on the frame already. maybe I'm making more out of this than required. terry |
what kind of seat is it? glue will hold it then when you stretch your cover you hog ring it in the back...depending on what kind of seat it is....weldwood contact adhesive will work...older mustang seat covers are glued and there a B&@ch to get off so it holds well...
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ Last edited by DanTwoLakes; 11-05-2009 at 07:25 AM. |
DAP Weldwood top and trim adhesive, 3-M top and trim adhesive, Helmetin green top and trim adhesive are all good contact adhesives. Kwik-Spray 220 or 225 and K-Grip 201 or 203 are good foam to foam glues. Kwik-Spray 220 is a lower viscosity and will spray from a Critter sprayer. Kwik-Spray 225 is heavier and would need a spray gun with a bigger nozzle. These are all spray grade adhesives. Aerosols work somewhat, but to make sure it lasts forever, use a spray grade adhesive. The picture is a Critter sprayer. Stay away from 3-M 74 and 77 aerosols. In my experience they just don't work.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
| Recent Interior posts with photos |
| Question about vehical weight and engine question | Thuggishruggish3000 | Engine | 12 | 03-24-2011 05:22 AM |
| question about a previouse question | elrod1030 | Engine | 6 | 03-10-2010 07:35 AM |
| 383 stroker | 73monte | Engine | 10 | 12-05-2009 08:02 PM |
| Switching to 200R Tranny question | Gundarak | Transmission - Rearend | 4 | 12-05-2003 08:00 PM |
| nitrous | 69BiRd | Engine | 2 | 11-28-2003 10:33 PM |
