question on brake shoes - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-23-2008, 07:36 PM
bought a truck that has problem with back up only
when you back up it only goes about 30 feet when the truck seems
to just stop on it's on accord .
keep on the gas and off the clutch it keeps going in reverse , but
it's like the brake is on .
all gears and bearings ok in rear ,even the spider gears ,checked them all today.
axle bearings look good also .
trans not it ,does fine on jack stands .
the brake shoes are new , but noticed the front short pad shoes are thin .
the back large pad is thicker .
both pads are tapered at ends , not square cut .
all springs are good as new .drums are good in size also .
would the shoes be my problem ?
never seen shoes with different thickness in pads on them .
Old 01-23-2008, 07:56 PM
T-bucket23's Avatar
Wiki Edits: 26
Did you check the e brake cables to make sure they ae fully released. Are you sure that all the hardware is assembled propery, especially the e brake hardware, I have seen a lot of weird stuff happen when its not. Poorly turned drums can also cause issues. Take a pic and post it if you can.
Old 01-23-2008, 08:09 PM
all in good shape on the cables and drums as stated early .
my photos won't shrink enough .
the pads are all i can see that are different .
i have two of these trucks the same year and investigated both side by side .
swapped drums and still problems occur .
bought new shoes for tomorrows cold day in here .
the new ones are same thickness ,short and long shoe , but not as thick as the ones on the rear shoe thats on the truck to begin with .
Old 01-23-2008, 10:15 PM
T-bucket23's Avatar
Wiki Edits: 26
maybe that set of shoes that are on there are no good.
brake question marlene kit car Suspension - Brakes - Steering 8 09-24-2006 01:20 AM
brake master cyl question! 67 Deuce 4 Me Suspension - Brakes - Steering 3 08-08-2006 01:47 AM
How Does This Stuff Work? docvette Electrical 3 06-18-2006 04:00 AM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 07:17 AM
brake question Tissue Suspension - Brakes - Steering 5 03-22-2004 06:28 PM
