Question for Cam Expert or Engine Builder
I have a 350 block bored +.060 with stock rods and crank
Deck Height is .024 down the hole with KB 193 (12cc Dish) with .016 fel pro gasket im at .040 quench. Using Vortec heads casting 906 with a little pocket porting done. Edelbrock performer rpm vortec manifold Q-Jet Carb rebuilt The cam i was thinking about was the Voodoo 262 Pt# 60102 The Dilemma I am having is that with flat top pistons my CR is about 10.28:1 and DCR is around 8.3 Which i thought was high even for premium. On the other hand, if i use a 12cc D dish piston my CR is 9.73:1 and DCR is 7.89:1 it would be easier to run the flat tops but i dont want to have to put airplane fuel in it all the time or something. My climate is pretty cold too. i live in north dakota so it rarely gets over 80-90 even on the hottest of days. The rpm range seems to be about right for my needs. I am using this in a 1969 C-10 Pickup with th350 trans with stock converter and 3:73 12 bolt posi If you have any questions for me please reply. Also, if you think another cam choice which would be better please let me know. Thank you for your time, Logan |
Im not trying to fix the CR with the cam. Im just weighing out my options. The falt tops are $80 cheaper and dont have to be back ordered. Why would i want to run a .026 gasket? that would make quench .050? im almost positive .035 to .040 is optimum.
i had someone on this forum tell me about this software and i am prity much in love with it. go to comp cam and download CamQuest. you input all of your information about your truck and it will give you the best cam grinds to take advantage your setup. tho it it only gives you comp cams but you can just transfer the lift amount and grind angles to different companies. hopefully this helps, it helped me out a lot.
| New engine and Builder | 84chevys | Hotrodding Basics | 4 | 09-05-2009 05:25 AM |
| I need a engine builder | F3RR3T | Engine | 5 | 10-02-2008 06:06 AM |
| engine builder and mfg. | inline64 | Engine | 1 | 03-31-2008 03:30 PM |
| Two Dead Pistons??? Question For The Expert!!! | mike65 | Engine | 71 | 04-08-2005 10:02 AM |
| Tax question... Any expert on federal taxes out there?! | killerformula | Hotrodders' Lounge | 0 | 08-17-2004 12:10 PM |
