question on cam & oil pump install chev 350 - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-02-2002, 09:51 PM
New Member
Post
I think Liquid-larry is correct, I read somewhere that non roller cam lobes had a slight "lean" to them so that the cam is pushed back by the lifters,to keep it from walking.
  #17 (permalink)
Old 04-03-2002, 05:25 PM
Wink
Hot 57 is right, this taper on the cam lobe not only pushes the cam back it also causes the lifter to spin, ensuring that the lifter face wears evenly and also transfers heat to the oil lubricating it. The only oil on the lifter face is from oil that is being thrown off from the crankshaft, (referred to as crankcase windage).
