Does anyone have any experience with the Classic Performance Products (CPP) 500 Series power steering box? I am trying to find an alternative to my Gearheads modified 605 box and think I have something here. The CPP box is for a 55-57 Chevy and the sector shaft is the same length. Basically it has the same dimensions as my 605. The only difference is one of the mounting holes is off a little but I can just drill another hole in the frame to fix this and weld up the original hole. It sits on the frame in the same position as the 605. I also have to use a 56 ford steering sector arm because of the design of the teeth. (It a perfect fit) This arm is the exact same shape as the 60 T-bird arm with exception of the teeth. I am a diehard Carlisle nut and was able to piece this together without too much hassle. Also, these boxes are new and not rebuilt.
I am sure everything will sit in its proper position as the original but I just wanted some feedback on the CPP box. Thanks.
