question on the CLEAR TEST - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 11-13-2006, 07:35 PM
Who is that goofy big lug in the reflection. Color, I hear bondo is a pretty big dude, I'd make sure to stay on his good side
But if he can put up with Jim(dad) all the time without getting angry, he must be a big ole teddy bear at heart.
I normally try to use the coarsest grit on anything I can get away with, just feel that it would make it better against chips ect in the future. I am not doubting you at all, but man 320 does sound coarse. Could you sand before base that coarse? I never heard anyone recommend much more then 400 before basecoat cause it may not fill in the scratches and be magnified by the clear. Could you sand with 320, fix a spot with base before you do your reclear also, or is this only reclearing the panel, spraying no color.
  #17 (permalink)
Old 11-13-2006, 08:05 PM
adtkart@aol.com
I have sprayed SPI bases over 320 DA sanding and had it come out smooth. I have also done it with SW one time, but was kind of nervous with that one, as I didn't pay for the paint.
There is a diffeence between spraying more clear over 320 scratches in clear, and spraying clear over base that has 320 scratches showing.
Aaron
  #18 (permalink)
Old 11-14-2006, 04:43 AM
My mind kinda drifted. 320 machine dry is about the same is 400 wet. I've wetsanded before base with 400 without problems. But hand sanding with 320 dry is suppose to be coarser. But still goes against everything you were taught, when doing a repair on the panel, the places that would only recieve clear were sanded finer then where your repair area is and will be receiving more base.
  #19 (permalink)
Old 11-14-2006, 05:48 AM
BondoKing's Avatar
KING OF BONDO
Last journal entry: My little helper
I dry sand my clear with 3M 320 guys... I also have dry sanded epoxy or primer before base and clear without issue... Most are scared of the number, just like years ago they myth was taught you had to use 1000 to sand for a re clear.. The myth has been broken and still yet. people refuse to believe what is real and what is not... It is a matter of choice gentlemen... Use whatever grit you want... I use what Barry has proven to work and what I have trusted and proven to work myself... Try a test panel for yourself ya'll instead of just wondering and saying " it just cant be so".. Barry has been painting for 37 years, he owns his own paint company, he makes his paint, he has his chemistry degree... well you get the point....
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
383 stroker 73monte Engine 10 12-05-2009 08:02 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
I.Q. test willys36@aol.com Hotrodders' Lounge 57 11-25-2003 09:34 PM
