Question for Crosley or Jakeshoe 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-25-2009, 11:55 AM
Have either of you ever scarf cut the turbine shaft oil sealing rings? What is the best method of installing these rings?
Thanks in advance
Old 03-26-2009, 12:30 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
Just a bump
Old 03-26-2009, 07:34 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks in advance
yep ,I scarf cut them often. I prefer the L cut sealing rings on the input shaft.
Best way tooi install the solid rings is with the proper tool , about 90 bucks that last time I looked.
Old 03-26-2009, 09:49 PM
What are you calling L cut , the cast iron type that has the hook type latching?
Thanks, Gerald
Old 03-26-2009, 10:27 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Thanks, Gerald
there are L cut teflon sealing rings... as they sit in the groove / land area... the rings fit tightly via the shapes of an L . Not the interlocking design of the metal rings.
700r4 down shift question Jake_Dragon Transmission - Rearend 18 01-10-2009 04:29 PM
86 Chevy k10 4x4 700r4 , converter question frontierstorm Transmission - Rearend 0 05-29-2008 12:02 AM
another 700R4 tranny question ?? cares Transmission - Rearend 6 06-16-2006 02:26 PM
700R4 Question Not A T 25 Transmission - Rearend 5 06-12-2006 12:16 PM
700R4 Filter question UnionWrkr Transmission - Rearend 5 03-12-2004 08:41 PM
