question of the day (HELP)!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2005, 09:41 PM
I recently replaced a 4.3 vortec with a 5.7 in my k10 chev. I purchased the 350 used after hearing it run. It runs strong as heck and has a mild cam in it. Problem is after driving it a few days I noticed a knock. It sounds like the exhaust rattling on the frame at idle, problem is its not the exhaust hitting anything. I cant hear it while im under the truck and while im above the motor it almost sounds like the sound is coming from the bell housing although I cant be positive. And in case your wondering ...no the dust cover is not on right now. The other delema is the sound is not their when the motor is cold...only after driving it for 15 to 20 minutes. Now im afraid to drive it anydistance for fear of ruining somthing...any ideas.
Old 10-16-2005, 10:10 PM
Take a really good look at your flexplate for cracks, and also make sure the torque converter bolts are tight. It may also be a rod knock or piston slap. I've heard cracked flexplates that sound just like a rod knocking.
Old 10-16-2005, 10:19 PM
347mustang's Avatar
i agree, when cold the crack are tight , when the flywheel heats up from engine heat it opens the crack,
Old 10-16-2005, 10:41 PM
the flexplate is new but i suppose it could be loose thanks for the help i really appreciate your input
Old 10-16-2005, 11:02 PM
gROCERYgEtteR's Avatar
Guy i work with the other day has this old beater Chevy, said come listen to this, been doing if for a while but not sure what it is and it just got worse.
It sounded like a knock from the top of the bell housing, he didn't have his cover on, so I told him to checked to see if the noise goes away when he put it in gear.It did, most of they way I told him to climb under it and look to see what is stuck in the bell housing , assuming some road debris, he got down there called me over and said take a look, two of his bolts had backed out and the tranny was slipping away from the motor, there was about a 1/8- 3/16 gap , a little lock tight and a couple of turns, noise is gone, I hope his bearings last.
Old 10-17-2005, 10:57 AM
71 c-10's Avatar
just a kid and his truck
the other day at my shop a car came in that had just been baught used for us to check a ticking noise. We get under the car while its running, then turn it off. looking around we see that the flex plate had craked, and then some one had welded it and the slag was hitting the motor we told them to promplty take the car back have a talk with the seller.
383 stroker 73monte Engine 13 05-11-2016 12:17 PM
supercharger.... 73monte Engine 16 07-24-2010 11:27 AM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 02:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 11:25 AM
What a great day! 32vicky Hotrodders' Lounge 10 11-16-2003 02:31 AM
