Question for Deuce, details on bent 32... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-04-2008, 03:03 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
To quote an ongoing thread that I don't want to mess up...
... you never know how many times the 32 was treated to a " Dukes of Hazzard " style of ditch jumping. I had a nice original frame from a 32 4 door ( 42,000 mile nice old car ) and the frame was off almost 1/2 inch at the cowl on the right side. Had to tie the chassis down, heat the general area of the frame rail with a rose bud and then use hydraulic power to bend the chassis rail back up to spec. The chassis was not yet boxed.
My latest frame is an OLD school rod frame that sat for 50 years I'd bet. The driver rail is bent at least 3/4" just by eye with a straightedge, comparing sides. It is bent almost at the firewall, EXACTLY where the 2 side rivets hold the front leg of the K. I found it hard to believe it bent where the K brace equals double frame thickness? I've set up a beam, chains & jack, but would rather ask first
They boxed the rails AFTER it was bent I cut out the plate from the front K brace, to the steering side hole for the stock pitman. There is slightly "bunched up waves" on the top surface, but not too much on the side. But you can really notice a sharp angle bend on the bottom flange where it should be a straight taper downwards towards the rear.
Should I cut loose that front K brace (all the rivets) BEFORE I heat & jack? I can see doing it either way should work. The K will be removed for good after I set up suspensions & temporary frame cross bracing. I'd hate to take it out right now. My body has no reference mounting holes, and I want to do sills & floors first.
Where/how much, did you heat? As a guess, I'd try not to get the bottom flange too hot, but a 4" long red spot on top flange, tapering down the side, to the lower flange?
I know you take lots of pics???
Old 06-04-2008, 03:51 PM
Tough call ...
There are good sets of 1932 Ford frame blueprints on eBay ... I believe I would just cut everything away and get down to a bare pair of rails. The frame is just like a foundation for a house. I understand not wanting to cut it.
I like running the original rails with the number on them ... stamped by Henry Ford's crew ... especially if I have a good valid title that matches that number. The time is coming ... IMHO ... when those numbers may really mean something. In North Carolina now ... the DOT has been out checking older cars for serial/vin numbers because of the influx of NY state registrations and folks trying to register glass cars as 32 Fords.
Just my nickel.
If you look closely on my 32 3W rails ... you can see a little ripple in the right frame rail near where the hood would be Easy FIX ...
No photos of bending the right frame rail on the 4 door chassis ... it was a few years back and I did not own a digital camera at the time.
Old 06-04-2008, 06:27 PM
F&J F&J is offline
I'm not tearing down right now for 2 reasons.
First & most important, is that I can't go an inch further on saving the tired old body until I get a straight platform that measures out to the Wescott PDF. I love doing the metalwork and I couldn't even try out the Spadaro rear floor due to the orig chassis having coil pockets too high up.
The 2nd reason (for doing some suspension now) is making the project a roller to bring into the work area quickly when I get spare time. Then if I can finally rough in which old ford parts are going to be used, I can get rid of the TONS of other ones I am tripping over
I really look forward to doing some major structural body stuff soon, before I go nuts with other life obligations.
'32 ford question bonuts Body - Exterior 9 02-18-2009 03:23 PM
Hotrodders Guidelines -- READ ME Jon Interior 0 06-14-2003 04:59 PM
Hotrodders Guidelines -- READ ME Jon Transmission - Rearend 0 06-14-2003 04:58 PM
Hotrodders Guidelines -- READ ME Jon General Rodding Tech 0 06-14-2003 04:57 PM
Hotrodders Guidelines -- READ ME Jon Engine 0 06-14-2003 04:53 PM
