Question on early Ford front hubs
In my Mysterion reproduction project I have come to the point of building the front end. I need two early Ford hubs but I am confused. I thought they were all the same (I know nothing about early Fords) but found there are at least 3 styles.
Here is a picture (the best one I could find - not much exists about this car unfortunately). ![]() Here are a couple photos of hubs I have found. The red one on the left has a smaller rim OD, slightly larger hub ODs (like 1/16") and larger rear bearing although the dust seal is the same OD as the other two hubs shown. The two (middle and right) others are similar in flange diameter and rer bearing size (small OD than the red one.). All could work but from the first picture I think I need the one on the right. ![]() My questions are; Do you Ford experts agree that I need on the right with the raised bolt bosses and straight rear hub diameter? If so does anyone have a set that could be chromed (EVERYTHING on the Mysterion is chromed!) that they would well or trade for a set of the red hubs? I have a super clean set of the redo ones w/ good lugs and bearing races. Also if someone can use the other two rusty hubs (right one is in good shape, middle one is heavily rust pitted around rim, hubs and bearing races good on both) I will gladly give them to you, you pay shipping cost. |
no luck.
You will probably be able to search the answer or ask on the HAMB forums.
An interesting detail I have discovered; Ed installed the tie-rod ball joints (20 on the car!) with the rubber seal cups on backward! Lots and Lots of strange little things like that on the car.
brake hubs
Somewhere I read an article on identifying Ford brake hubs.spindles Etc. some mount the drum on the outside and some on the inside. I should have printed it out for future reference. I have a 46 lincoln front axle out of a hay wagon, a 40's Ford. axle from a trailer, and model A axle, and fined buick front brakes. Ford F 1 axle and extra F1 spindles. some pieces adapt better than others.
Brian |
| Someone ejumikate me - early Ford front hubs | Centerline | Suspension - Brakes - Steering | 6 | 02-19-2008 10:03 AM |
| early nova hubs needed | Prof. T. Soggmeyer | Suspension - Brakes - Steering | 10 | 12-11-2006 12:07 PM |
| What front hubs (brake drums) fit a 52 Ford pick-up | lakota | Suspension - Brakes - Steering | 3 | 12-27-2005 11:56 PM |
