Question on electric fuel pumps and fuel cells.
Hello guys got stranded today because my Mr Gasket universal inline electric fuel pump took a crap on me on my way to work. The thing only costs around 40 bucks so I know they are not the best since I have been through two in the last year. Ok I was looking for a new pump to get soon and was looking at the 80 dollar inline fuel pumps from jegs and summit under there name brand. Are they any good? I want an electric fuel pump that will last me for several years and get my money worth out of it. I don't want to have to buy a new fuel pump every 6 months. This is a 96 chevy s10 with a 350 v8 with a carbuerator. The pumps I was looking at are for carbs. The people who owned it before me put the pump on the transmisson crossmember and is that to far from the fuel tank and is the reason whey they keep going bad on me on these Mr gasket pumps? I can get a new summit one or jegs and they are a more performanace type electric fuel pump but if I mount it close to my tank if will sit up a little higher then where my line come out. Also need to replace my gas tank anyways its rusting out. Can a fuel cell fit underneath this thing buy chance? I don't want to have to pay 300 bucks for the plastic sendind unit and another 200 plus bucks for a new metal tank when I can get a fuel cell with a sending unit from summit for around 150 bucks. I don't want to fit it in my bed cause I still use my truck to haul stuff. Its just a 2wd and would still like to be able to fill it from the side. Can this be done?
Eric |
Carter also makes a inline electric that is quieter than the Holley style. Mallory makes some of the nicest quiet electrics, but they are more expensive. The Jeg's and Summit pumps are Holley style pumps, kinda noisy but work just fine.
Hi,
Unless you have a working pump in the fuel tank, you will want to mount your electric pump as close to the fuel tank as possible, I have been using an MSD pump now for three years w/o any problems, but my pump is for FI, you would need one for a carb. Good luck, Rich |
for the fuel cell maybe u could either put it wear the spare tire usually goes are get one of those tall wide narrow cells and put it wear the original was maybe just a thought
Well I would use a mechanical pump but I have the late model 350 vortec block and it does not have the provision for a mechanical pump thus I have to use the electric one. I will have too see if I can get a fuel cell like the one you mentioned. Thanks guys for info. I can't use the fuel pump in the tank cause I am using a carb not Fuel injection.
Eric |
elc fuel pumps
have a carter on my 302 in 32ford it is 3 years old, car would not start problem was the fuel filter on the carb side,as fuel pump 3to4 psi it could not get past filter, yes i know filter should be on suction side
I agree with what was posted above, the electric fuel pump is too far away from the tank. It should be mounted as close to the tank as possible, since the electric pumps work better as pushers than as pullers.
Another option is to use the stock FI pump in the tank with a few modifications to the fuel system. You should be able to use the stock FI fuel pump in the tank if you run a carburetor style bypass fuel pressure regulator. Here's an example. http://store.summitracing.com/partde...&view=1&N=700+ Using something like this should allow you to use the stock fuel injection fuel pump and still have the carbureted engine. You'll need a return line at least the same size as the supply line from the pump to the regulator to return the bypassed fuel back to the pump, but this style regulator will bump the line pressure from the 50 or so from the stock pump down to about 7 for your carb'd application. |
On my fullsize i run my fuel cell in the bed, and run two fuel systems, one for the nitrous, and one for the carb. I run holley blue pumps and mount them on the frame rail right beneth the tank. No problems, they are noisy but i dont mind it and you can barely hear it when your driving, not bad at all. Been running the holley blue since 05 with no problems, make sure you use a regulator though. Also i do not run a return on either systems and no problems!
Well I was thinking about what it would take to put on a fuel cell etc. I will keep my old fuel tank where it is and just have to cough up the cash for a stupid sending unit and a new lock ring for it cause my old one is rotted away. I will then get a summit or jegs pump for 80 bucks and mount it as close to the tank as possible. Would be a lot less headache for me that way. The cheap Mr gasket universal pumps are junk. I did not even have a thousand miles on my last pump before it went bad. Paid 40 bucks for it and its not worth 4 bucks in my opinion. It says on paper will give you years of trouble free performance, yeah right. Thanks for help guys will maybe try the carter pump since it come with a bracket etc. That will help out.
Eric |
I've been running that mr gasket pump for over a year, the first one was bad but not the 2nd one. Make SURE there is a filter BEFORE the pump, especially where you say the tank is rusty. If there is no filter before the pump then i would say that is your problem
| Electric fuel pumps - Marine vs. Automotive | Centerline | General Rodding Tech | 1 | 07-21-2008 03:12 PM |
| Electric Fuel Pumps | Corvair John | General Rodding Tech | 4 | 05-16-2007 11:00 PM |
| Electric fuel pumps....for a boat | WakBordr7387 | Engine | 5 | 10-23-2006 08:10 AM |
| TPI and 2.8 LITER ELECTRIC FUEL PUMPS WANTING INFO | boneyard Buick | Engine | 0 | 03-18-2006 09:08 PM |
| Electric vs Mechanical Fuel Pumps | slomotion | Engine | 2 | 06-23-2003 01:42 PM |
