Question on F-BIRD'88 Build - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2008, 11:41 PM
DENCOUCH's Avatar
Okay, I am in a bind with my sbc 350 build, and I am finding myself in need of some info:
1. I understand that the top piston ring on my flat top Hypereutectic Pistons need to be gapped a bit more than standard rings. What I do not know is how much that should be.
2. When I was painting the block, I managed to get some over-spray into the bores, can I wet sand this stuff out & clean it up with something like 280 grit before assembly?
3. Would it be a good idea to remove any paint on the cam cover & oil pan gasket surfaces as well?
4. The Vortec heads have been shaved .045 and now the volume cc's out to 60cc. Can I still use the Felpro .015 steel shim gasket? I installed a lift rules Isky cam, Intake duration: 278 deg. Exhaust duration: 278 deg.
5. Along what lines should I be considering for timing now? I have an HEI and I would like some suggestions as far as total advance. How fast should total advance come on? Would one of those toggle switches come in handy to allow the motor to spin a few revs before giving it the spark?
6. any suggestions on the Plugs I should be using? Heat range?
Thanks fellas, I am wanting to get the pistons & rods installed soon.
Old 06-19-2008, 12:05 AM
SSedan64's Avatar
#1: Info should come with the piston, rings
#2: Yes in a cross hatch pattern.
#3: Yes, no paint on gasket or seal suface
#4: Yes if Deck height isn't to low. Try .040-.045"
#5: Timing all in by 3000rpm. Total Timing 34*,Toggle=Yes,
#6: ?? Not sure.
Old 06-19-2008, 03:27 AM
ericnova72's Avatar
More for Less Racer
The 280 emery is way too rough to be using on cylinder walls, scotch-brite is a much better choice, just lacquer thinner is the easiest way.
Old 06-19-2008, 05:46 AM
31 five window
Last journal entry: grill and rear end
Yes to lacquer thinner,no to sand paper of any kind.
Old 06-19-2008, 07:44 AM
Banned
yea... using 280 grit sandpaper just throws your machine work out the window. Just use laquer thinner.
Old 06-19-2008, 06:40 PM
DENCOUCH's Avatar
Thanks guys.
Thanks for the particulars. The torque converter is on order from Jegs,
Jegs torque converter
I picked up the rings today.
My weekend is planned, thanks!
Old 06-19-2008, 06:45 PM
King of my Man-cave.
Unless you are using KB or Silvolite hypereutectic pistons, you do NOT need additional ring end gap.
tom
motor build question Casperdude898 Engine 16 10-28-2007 11:08 AM
newbee question about 383 build jgaona Hotrodding Basics 5 08-17-2006 04:03 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 02:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 11:25 AM
Water Pump Question Kaylah Engine 11 08-22-2003 10:35 PM
