Question on HEI rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2003, 07:12 AM
I haven't been able to find an answer to my question by searching so I am hoping you guys can help.
After disassembling my HEI distributor I find that the hinge pins for the weights are worn quite a bit. What are my possible solutions to fix this?
I would really like to replace the pins but can't find any.
Thanks for your help!
Old 07-11-2003, 08:11 AM
11echo's Avatar
Old Guys Rule!...EVERYTHING!
AND you won't find a replacement pin either! GM will gladly sell you a whole new dist. but that's it (been there, done that). Now the good news, if you go to the junk yard and pick up an early HEI (75 -77) their weight pins are hardened and don't wear like the newer ones. OR I've seen some after-the-market weights, where they have plastic bushings for the pin holes in the weights. I think "Mr. Gasket" puts these out ...I tried these too, but ended up in the junk yard looking for the early HEI dist. GOOD LUCK! ...Mark
