A question on Instrument wiring - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2008, 01:02 AM
hot_rod_kid's Avatar
axes wayy too many questions
Last journal entry: Car show Btt50's 2012
Just started doing some rewiring under the dash, and on the Instrument cluster I see some of the lights have 2 wires coming from them, and some have only one. Are the ones with two wires a separate way to ground? I also notice the ones with only one wire have some silver metal on the clips, which makes sense as to why the ones with two wires do not; a way to ground.
Old 08-11-2008, 01:10 AM
powerrodsmike's Avatar
Wiki Edits: 161
Chances are, the lights with 2 wires are your oil pressure light, and your generator light. These lights need one lead to be hooked to the accessory side of your ignition switch, and the other lead to the oil pressure sender, (light type) and voltage regulator or if you are running an alternator, your exciter wire.
later, mikey
BE different....ACT normal.
Old 08-11-2008, 03:55 PM
later, mikey
That makes sense too. Thanks for your help.
Old 03-04-2011, 12:01 PM
need advice to buy wire
Hi folks, stupid ? but I cant find that old wire,the blck and yellow stuff ..want to redo my 21 studebaker ,so I need wire for lighting,gauges...also , does anyone know of stude people up here in maine?
If I can help let me know,as stupid as I am the old man did teach me studebakers or is that stupidbakers?
Old 03-05-2011, 04:10 AM
EOD Guy's Avatar
http://cgi.ebay.com/ebaymotors/NOS-S...Q5fAccessories
CS130 Wiring Question Blaster Electrical 4 07-04-2007 04:48 PM
MSD 6AL question about wiring hemigremmy Electrical 2 06-05-2007 09:48 PM
Alternator Wiring question 65Stanger Electrical 8 04-29-2006 02:28 AM
Painless wiring harness question Big Geek Electrical 9 02-28-2005 03:30 PM
85 s-10 distributor wiring question strracer7 Electrical 1 09-29-2003 03:39 AM
