Question for the interior guru's - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-03-2004, 02:13 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Part of this is from another thread asking about the car, but the pic brings a question to mind....How is this door pull made? It looks cool but I would like to know how the base would be and how the fasteners would be mated to the door. Would retainers be put on the inner door and then screw / bolts run thru the retainers? And what would the actual handle be carved / molded / made out of?
Old 12-03-2004, 02:49 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Panel base is probably 1/8"polyethylene sheet since it is bent on the top. Permanently bend to the curve with a heat gun. If a panel is pretty flat you can use 1/8" Masonite & Luan plywood. The arm rest can be made of anything you want - easiest way is use wood (2 x 4s, plywood, etc.) and cut, glue, grind and sand to shape. Cover it separate from the rest of the panel and glue and screw it to the door from the back side once the rest of the upholstery is on. If you use enough clips described below attaching the panel to the door, you don't need to anchor the pull to the door. If you wanted more security , you could use a finger bucket from a junk yard car and screw it to a bracket attached to the door, which is what it looks like this guy did. The various different material sub panels on the door are usually more 1/8" panel material cut to shape, covered separately and glued to the base panel. The panels are covered with 1/8" or 1/4" closed cell foam rubber before applying the upholstery material for smooth and pleasant feeling texture. Attaching the panels is super simple. Just align the bare base panel to the door before covering it and drill a series of 1/4" holes through the door and panel @ ~6" spacing. Snap one of these clips into each hole and the panel pops off with a screwdriver and reinstalls with a shove of the hand on each clip.
