Question on LS1 starter current draw - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2009, 09:43 AM
I'm attempting to go to a continuous duty solenoid for a battery disconnect. I am wanting information on the amperage draw of a factory starter on the LS1 motors.
Old 07-16-2009, 10:23 AM
Eric63M's Avatar
Last journal entry: Getting all the parts together for my LTX build
I wouldn't go with one that will only work with the amp. draw from the starter. I would go a little over-sized.
I work alot with master power switches (relays). Every vehicle in the Army has a relay for the master power switch. They are rated above what the batteries (anywhere from 2-8, wired in either series or series parallel) amperage will put out.
The oversized relays that we us provide longer life to the relays, occasionally you might see them fail, but when new vehicles come in with too small of relays they always burn up.
Just my 2 cents,
Eric
ls1 gto question doubleD_white_t'a Hotrodding Basics 19 01-20-2009 09:56 PM
Starter Question ss396si Engine 4 12-28-2008 04:46 PM
Starter question sexypizzaman Electrical 3 11-20-2008 09:51 PM
starter grinding update Powermaster starter question RossR90 Engine 2 08-11-2008 02:46 PM
ford starter question mikeweyman Engine 3 05-03-2003 02:55 PM
