-   -   Question for metalworking guys (http://www.hotrodders.com/forum/question-metalworking-guys-75206.html)
ckucia 12-02-2005 09:09 AM
When I learn about something new, I tend to mentally try to apply it to things I see.
Lately I've been thinking a lot about the bondo-less metalworking techniques discussed at length on the board.
Last night, I was looking at my truck (2000 Sierra). I noticed there is a welded seam where the back section of the cab, behind the door is attached to the door sill/rocker panel.
Was thinking that, if I were ever to paint the truck, I'd want to fill that seam in. Its a shallow line about 3/8" wide and maybe 1/8" or 1/16" deep.
In the past, I would have just spread a little bondo over it and been done.
Now I'm wondering how I would handle it without bondo.
Best thing I can come up with is to fit and weld a thin strip of metal over the gap, but I'm wondering if that's the best solution. Perhaps filling the area with weld and grinding it down?
What would be the best (hypothetical) way to handle this?
MARTINSR 12-02-2005 11:07 AM
I know just the seam you are talking about, hung my fair share of rear cab corners. I would simply weld it up and grind it smooth.
Beenaway2long 12-02-2005 11:56 AM
The other way, would be to use a pick and dolly, and hammer the recess forward. Won't be easy, for sure, but it is possible. They also use a Bullseye tool, for blind work. Depending on how anal you want to get, you can even raise the recesses left from tig welding, and the use a shrinking wheel to knock down any stretched materials. Look for Bondo on Randy Ferguson's Willys. (Randy's customer's car)
ckucia 12-02-2005 12:21 PM
Thanks guys.
I'm really "gettin into" this bondo-free bodywork stuff. Not that I have anything against bondo, but it always seemed like all-metal bodywork (other than with lead) was far beyond anything I could do at home. It sort of takes things "up a notch", plus, it never hurts to have some extra uncommon skills - ya never know what the job market's going to bring in the future.
After reading the various threads, I can't wait to give it a try on my next project, whatever that ends up being.
sha_ba_do_bang 12-02-2005 03:04 PM
I hope you've been over to metalmeet.com, this is prolly the best website and or resource for metal working anywhere! You can learn so much by reading the past posts
Brendan
advanced design 12-02-2005 07:03 PM
Originally Posted by ckucia
Thanks guys.
Ckucia,
Kudo's to you for "gettin into" bondo-free bodywork stuff and understanding the quality of what can be accomplished. My eyes were opened and my own standards raised when I started hanging out with Randy Ferguson. Plus, once you increase in metalshaping skill it doesn't take much more time than using filler and sanding. Good luck with your efforts and as the previous post said, check out MetalMeet.com.
