Question for metalworking guys - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-02-2005, 09:09 AM
ckucia's Avatar
When I learn about something new, I tend to mentally try to apply it to things I see.
Lately I've been thinking a lot about the bondo-less metalworking techniques discussed at length on the board.
Last night, I was looking at my truck (2000 Sierra). I noticed there is a welded seam where the back section of the cab, behind the door is attached to the door sill/rocker panel.
Was thinking that, if I were ever to paint the truck, I'd want to fill that seam in. Its a shallow line about 3/8" wide and maybe 1/8" or 1/16" deep.
In the past, I would have just spread a little bondo over it and been done.
Now I'm wondering how I would handle it without bondo.
Best thing I can come up with is to fit and weld a thin strip of metal over the gap, but I'm wondering if that's the best solution. Perhaps filling the area with weld and grinding it down?
What would be the best (hypothetical) way to handle this?
Old 12-02-2005, 11:07 AM
I know just the seam you are talking about, hung my fair share of rear cab corners. I would simply weld it up and grind it smooth.
Old 12-02-2005, 11:56 AM
Beenaway2long's Avatar
or Jeff, or Doc, or...
Last journal entry: Results of the Camaro
The other way, would be to use a pick and dolly, and hammer the recess forward. Won't be easy, for sure, but it is possible. They also use a Bullseye tool, for blind work. Depending on how anal you want to get, you can even raise the recesses left from tig welding, and the use a shrinking wheel to knock down any stretched materials. Look for Bondo on Randy Ferguson's Willys. (Randy's customer's car)
Old 12-02-2005, 12:21 PM
ckucia's Avatar
Thanks guys.
I'm really "gettin into" this bondo-free bodywork stuff. Not that I have anything against bondo, but it always seemed like all-metal bodywork (other than with lead) was far beyond anything I could do at home. It sort of takes things "up a notch", plus, it never hurts to have some extra uncommon skills - ya never know what the job market's going to bring in the future.
After reading the various threads, I can't wait to give it a try on my next project, whatever that ends up being.
Old 12-02-2005, 03:04 PM
I hope you've been over to metalmeet.com, this is prolly the best website and or resource for metal working anywhere! You can learn so much by reading the past posts
Brendan
Old 12-02-2005, 07:03 PM
advanced design's Avatar
Just havin' fun.....
Last journal entry: Wheels and tires
Originally Posted by ckucia
Thanks guys.
Ckucia,
Kudo's to you for "gettin into" bondo-free bodywork stuff and understanding the quality of what can be accomplished. My eyes were opened and my own standards raised when I started hanging out with Randy Ferguson. Plus, once you increase in metalshaping skill it doesn't take much more time than using filler and sanding. Good luck with your efforts and as the previous post said, check out MetalMeet.com.
question for the body guys..... zipfactor Body - Exterior 2 04-04-2004 05:09 PM
wyo tech @ laramie students ...question for u guys ... lowROLLERchevy Hotrodders' Lounge 2 03-15-2004 08:40 PM
I have a question and i was wondering if you guys could help me out Steveo9874 Hotrodders' Lounge 3 06-21-2003 12:22 PM
Hotrodders Guidelines -- READ ME Jon Hotrodders' Lounge 0 06-14-2003 05:08 PM
