Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Question on Pro Comp Heads on SBC and intake matching
Old 09-19-2008, 02:03 AM
wildman926's Avatar
wildman926 wildman926 is offline
Never let them see you coming
Originally Posted by y2k600f4
Looks like I will be removing the intake and getting it machined. I am going to order a new Felpro 1205 gasket and was wondering what other's opinions were on adding RTV (ultra Black) to the gaskets ?
I planned on smeering a light coat around the intake ports, and water ports and installing the gaskets letting that stand for a few minutes and then installing the intake gaskets and smeering a light coat around the intake and water ports ? I also planned on using the ATV on the front and rear of the intake (ditching the rubber or cork); which seems like common practice. Thanks.
RTV does not mix with fuel, unless it specifically says it is resistant to it. You only need to do the water ports.
