This should help you get the intake/head interface squared away and prevent shelling out cash for another intake manifold and still have the same problem....
http://www.crankshaftcoalition.com/w...ad%2C_internal |
If you think the Intake ports on ProComp heads are bad you should look at some of their Intake manifolds. They're terrible. I haven't had any problems with Professional Products Intakes. I've used their Typhoon/Eddy RPM copy & Crosswind/Eddy AirGap copy intakes.
The fact is I did not choose the components of the engine build and I agree if I was building the engine or having it built I would of did things different on the heads and intake....honestly I don't have the coin to start swapping out heads and intakes due to the $ I have invested on this new engine. Just wondered if others experienced similiar problems and if there was a solutions.Thanks techinspector on the article on getting the intake machined.. Sounds like the problem is more of the heads than the intake......
OK, then take the heads in and have a very light cut made on the intake side, just enough to see that they're parallel, then proceed with the exercise that I outlined.
Since you're contemplating an intake purchase, may I suggest that you ebay the scrap aluminum that you have and buy something else from a reputable manufacturer? Even if they're cast iron, Dart, World Products or even Summit stuff you likely gain horsepower and have no more problems. I know this isn't what you want to hear but the fact is that you'll spend more to correct this situation than it would cost to just eliminate it altogether. Larry |
Related question..new gasket and RTV
Looks like I will be removing the intake and getting it machined. I am going to order a new Felpro 1205 gasket and was wondering what other's opinions were on adding RTV (ultra Black) to the gaskets ?
I planned on smeering a light coat around the intake ports, and water ports and installing the gaskets letting that stand for a few minutes and then installing the intake gaskets and smeering a light coat around the intake and water ports ? I also planned on using the ATV on the front and rear of the intake (ditching the rubber or cork); which seems like common practice. Thanks. Last edited by y2k600f4; 09-18-2008 at 08:08 AM. |
i've never seen the procomp heads, but have heard both good & bad about them. pull your intake & look at the gaskets. you should be able to tell if their getting squished equally. do they line up with the ports on the heads & the intake? intake gaskets come in different thicknesses, maybe something to look at?
this link might be able to help. ask these guys, their using them. http://www.thirdgen.org/techboard/af...num-heads.html |
Update
Just pulled the intake and NO OIL in the intake ports....looks like the intake was sealed just fine (was a pain to remove). It looks like I will not getting the intake machined and I have no idea where the oil is going
| sbc Pro Comp vortec heads any good? | TheCiscoKid | Engine | 13 | 10-18-2012 03:31 PM |
| Vortec heads and standard SBC Intake Question | ComingApart | Engine | 16 | 05-11-2006 03:09 PM |
| Heads and Intake combo | black66 | Engine | 4 | 07-23-2005 11:33 PM |
| Question about porting my own heads | mouseman | Engine | 10 | 03-15-2005 06:47 PM |
| Head recommendation - low HP w/LT1 intake | Tim240Z | Engine | 0 | 07-08-2004 12:56 PM |
