Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Question for the Pro's
Old 10-05-2012, 09:19 PM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
Originally Posted by crsweet91 View Post
Heres how I do mine. I buy aluminum round edge flat bar, rip it down the middle and use each half as trim. 1/4" wide I drill and use tiny sheetmetal screws, 3/8" wide I drill and tap and use machine screws. After I make it up I polish, but you could finish it however you want.
Clayton Machine Works sells premade trim in I think 3 and 6ft pieces. Just drill your mounting holes. But compared to making it yourself it can get pricey.
Heres 1/4" trim polished and installed
Your solution is the best and cheapest alternative, but........a lot of people can't rip the aluminum, and Clayton Machine Works doesn't even offer a simple straight piece of rounded trim like you are making. As far as I know, there is no supplier that does, and I have looked everywhere.
