Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Question for the Pro's
Old 12-26-2012, 09:11 PM
carolinacustoms's Avatar
carolinacustoms carolinacustoms is offline
Automotive Extraordinaire
This is a great question and I hope some others will chime in because I look forward to hearing all sides of this discussion.....I have been guilty of using PPG base and dupont clear, as well as using standox base coat and PPG clear. Plus there are apparently shops using SPI products for primer and clear with the quality base coats (mostly BASF from what I understand) of their choice with Barrett-Jackson type results. So is it really a big issue to mix primers, bases and clears as long as all of them are quality products? Now I should say I am referring to compatible and quality products from different manufacturers
