Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Question for the Pro's
Old 12-26-2012, 08:21 PM
tech69 tech69 is offline
put up or shut up
If I'm using a clear I'd use that brand's activator but reducer not so important, but do try to keep it in line. I don't put much emphasis on having the same brand base as clear, but probably would if I had a lot more money cause in that case I'd get the top of the line all across the board, and the same brand, with the exception of blockable primers, but from sealer on it would be same brand.
