Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Question for the Pro's
Old 12-27-2012, 11:49 AM
mr4speed mr4speed is offline
Originally Posted by gearheadslife View Post
if there wasn't "fear" of one brand not working with someone elses,
no shop would stock or spray "sealer"
they'd just prime..
so the b/s that it doesn't matter is b/s.. as you'd skip the use of sealer and save both time and money..
anyone that says it don't matter, ask if they are spray'n a sealer coat. if they are, they were talking out their corn hole..
The only reason I spray a sealer is I always have sand throughs somewhere or another and bare metal on edges, as far as protecting one brand from another with a sealer just not true. As mentioned earlier above have sprayed different brands of primer, then a different brand of sealer, then a different brand of base and clear as well. There are a lot of guys on this forum that shoot SPI epoxy as a sealer then their own brand of base then come back with SPI clear. So the arguement is pretty much moot right there.
The Following 2 Users Say Thank You to mr4speed For This Useful Post:
carolinacustoms (12-27-2012), tech69 (12-27-2012)
