Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Question for the Pro's
  #20 (permalink)
Old 12-27-2012, 07:51 PM
tech69 tech69 is offline
put up or shut up
don't forget bleed thru. If you block on an existing paint and you had to go thru a layer or two a sealer is great at keeping things separated as to not create halos or rings or an edge sucking up the shine. If it does lift I'd rather be sanding on that and reseal lightly than trying to do it with base. Sealer is great insurance for a number of things
