Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Question for the Pro's
  #29 (permalink)
Old 12-28-2012, 09:43 AM
tech69 tech69 is offline
put up or shut up
Originally Posted by gearheadslife View Post
most times the baked on paint from the factory is a better base than going to metal and starting over.. depends on the car..
if it's a laquer paint on a all original car, I'd go to metal.. cause if it hasn't spiderwebed(checked) it will...
got to remember mid 80's and newer are 26+ years old now..
tons of these are getting rodded, as most don't have the green for the 64-72 cars,, or s 32-34 ford.. 55-57 etc..
myc-10(71) will go to metal, as the new paint buy the p/o (2000) lifted the oem paint, but not the primer under it.. no idea what gm used on trucks in 71 (enamel??) but the mid line duport pulled it up.. 30 years later.. if it was the new paint only lifting, I'd say p/o prep was the cause.. but it pulled the factory paint.. no sealer was used as far as I can tell.. from a d/a and feathering a spot
We're working on a 55 300 and it has the old school red oxide primer. It has a few areas that need patches but I'm astonished at how little surface rust is under areas with original paint/primer and how much more is under the areas that have been spot repaired. Not every job is gonna get stripped and sometimes I'd rather leave the factory zinc coating on the car along with at least the original primer.
