[QUOTE=gearheadslife;1627930]most times the baked on paint from the factory is a better base than going to metal and starting over.. depends on the car..
if it's a laquer paint on a all original car, I'd go to metal.. cause if it hasn't spiderwebed(checked) it will...
got to remember mid 80's and newer are 26+ years old now..
tons of these are getting rodded, as most don't have the green for the 64-72 cars,, or s 32-34 ford.. 55-57 etc..
myc-10(71) will go to metal, as the new paint buy the p/o (2000) lifted the oem paint, but not the primer under it.. no idea what gm used on trucks in 71 (enamel??) but the mid line duport pulled it up.. 30 years later.. if it was the new paint only lifting, I'd say p/o prep was the cause.. but it pulled the factory paint.. no sealer was used as far as I can tell.. from a d/a and feathering a spot[/QUOT
Factory paint is baked on...this is done to keep the assembly line moving...Body Shops that have an air make up unit with their booth also bake their paint to keep the production moving. Baking paint doesn't make paint better...paint will cure over time and be as strong as unbaked paint.
I'm sorry, I'd like to respond to the rest of your post but, maybe it's the fact that I don't understand all acronyms, I'm not sure but, I am having trouble understanding what you are trying to say. If you could help me out with what "p/o prep" means....does the p/o stand for pour overall?
