Based on my vast experience of rebuilding one air compressor pump 20 years ago, it's easy. Just use normal good practices and mic or plastigage the journals if possible. Know the specs and make sure when you put it together the clearances and torques are within spec. Make sure you assemble it the same way it came apart.
What he said, treat it just as you would an engine and adhere to general engine type rebuilding practices but think in terms of air cooled engines. Now having said that pay particular attention to the valve assemblies as these can be real trouble spots if ignored or just given a quick "once-over" type of inspection/repair. Usually on a compressor pump a lot of emphasis will be placed on the cylinders and pistons/rings when valve leakage is apt to be a major cause of compression loss.
When rebuilding Air compressors. Check the bore wear. The larger piston tends to be the worst. Due to heat and contaminents that get by the filters. Make sure oversizes and/or new piston/cylinders are available. Same for the crankshaft. Some manufacturers only offer standard or .020 rods (or bearings). Check wrist pins carefully. Replace the air valve at the end of the crankshaft (the one that bleeds off air on stop) and be sure the tube is clear. Check the heads for warp and replace the reed valves if that type of head. Old reed valves have a nasty habit of cracking soon after a fresh rebuild.
| Recent Garage - Tools posts with photos |
| Ford 351 water pump question. | el pollo | Engine | 18 | 01-25-2009 11:09 AM |
| High Volume/Pressure Oil Pump Question... | 71gtx | Engine | 1 | 05-14-2007 07:18 PM |
| high volume oil pump question | jstaten | Engine | 4 | 01-15-2006 11:56 PM |
| Lean backfire | Camaro76 | Engine | 5 | 04-15-2003 05:45 PM |
| 700r4 Front Pump Question | ChevyCam | Transmission - Rearend | 13 | 03-15-2003 07:23 PM |
