Question re. alignment of guide plates - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2008, 03:24 PM
v8hed's Avatar
AK427
I just installed the valvetrain on my new (used) heads. I'm using ProForm chromoly 1-piece pushrods and Scorpion full roller rockers. I've already checked pushrod length and I'm perfect on that front. In terms of lateral alignment of the roller tip on each valve stem, I did a quick check and they're all fairly central (not perfect, but close enough). However, I didn't check to see if the pushrods are rubbing against the sides of the guide plates. Should I check for that and adjust the guide plates if that's the case? What is more important; lateral alignment of the roller tip on the valve stem, or making sure the pushrods don't rub against the guide plates?
Thanks.
Old 08-21-2008, 04:15 PM
i like mine centered on top , if it's off to one side , it will wear that way causing a slight lean of push rod rubbing guide and wit eventually jump off .
i've had to grind the opposing side of guide and add , weld ,to other side to get them centered .
Old 08-21-2008, 05:22 PM
Jmark's Avatar
Some companies make over lapping guide plates. You can adjust them separately but when the studs are tightened down, they lock together. (one pair per cylinder) You need to get the rockers right on the stem tip. The push rods WILL rub in the plates, that is what they are for, to keep the push rod in place AND to keep the rocker on the stem.
Mark
Old 08-21-2008, 07:05 PM
Most of them have a "up" side. beyond that the shoulder on the rocker stud will pretty much limit your range of adjustment.
Old 08-21-2008, 10:12 PM
powerrodsmike's Avatar
Wiki Edits: 161
On all of the fords I've done I have had to cut the guide plate in 2 pieces, spread them apart enough to get the rocker tips centered over the tip of the valve, then weld them back up.
PITA, but if you don't want a rocker slipping off the tip, hitting the retainer and popping keepers out, that's what I've found you need to do.
I've only had that happen once, but it made me never want it to happen again.
Later, mikey
BE different....ACT normal.
383 stroker 73monte Engine 13 05-11-2016 11:17 AM
supercharger.... 73monte Engine 16 07-24-2010 10:27 AM
Rocker arm alignment on Dart Heads TurboS10 Engine 18 05-16-2007 09:50 PM
Ignotion Set-ups Native Gearhead Engine 8 11-29-2003 01:20 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
