question re: Ford 8.8 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-25-2006, 06:55 PM
i am considering swapping the dana35 in my tj for an 8.8 by all accounts this is a wise idea if i'm wanting deeper gears and/or taller tires.
is there any difference between the 8.8's in explorers (that everyone seems to pirate for the axle) and the fox-body mustang? they appear to be the same width 59 1/2" - 60"
i realise there are probably 4x4 boards that i could post on (and i likely will) but i am looking for as many viewpoints as possible and the way i see it, hotrodders are looking for as much strength as 4x4ers.
thanks in advance
Old 10-26-2006, 04:17 PM
S10xGN's Avatar
Gotta love a turbo!
Fox body cars (and Ranger P/U) will have 28 spline axles, Explorer will have 31 splines...mounting points/style will be different too.
Russ
Old 10-27-2006, 11:31 AM
johnsongrass1's Avatar
Race it, Don't rice it!
I have a freind really into Off Road and we compare differences in Circle Track all the time. I can't however, seem to find the reason the 8.8 and Dana are preferred over the 9".
Old 10-27-2006, 02:59 PM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
The 8.8 was originally designed to handle F-250 type loads and towing, it should take anything a TJ can do to it.
The 8.8 replaced the 9" mainly due to cost and weight. I think for a drag or circle track car the 9 is probably better, especially because of the easier gear change.
Old 10-31-2006, 02:10 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
The 8.8 was NEVER used in a 250. In fact made a sad showing in the heavy 150s as many puked under towing useage.
Old 11-01-2006, 06:32 AM
pmeisel's Avatar
My apology -- I am working off of my memory talking to design engineers of the day. I had a 250 and thought there was an 8.8 in it but I have never checked the charts....
Anyway it is still plenty strong for a TJ.
Old 11-01-2006, 07:32 AM
onebadmerc's Avatar
I need a bucket of arc sparks
I had a 8.8 in my 84 F150 4x4, the rearend didn't even make it to 100,000 miles before it fragmented. I then replaced it with a 9" out of a 1980 F150 and drove the truck six more months and sold it. I still see my old 84 F150 running around with the 9" under it every now and then.
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 02:26 PM
Ford 2 bbl carb issue - detailed question V Bird Engine 6 08-10-2005 11:43 AM
axle width of ford 8.8 Can drive 55 Transmission - Rearend 2 06-06-2005 12:30 PM
My S-10 Ford 8.8 swap write-up KNanthrup Transmission - Rearend 6 03-18-2005 11:12 PM
Ford 8.8 questions mike bryan Transmission - Rearend 2 05-17-2003 08:01 AM
