Question on SBC with 1 piece rear main seal - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2005, 02:15 AM
Jeeps Are Us!
Last journal entry: The Paint Shop
Dear Hot Rodders,
I'm going to change my 350 SBC block which belongs to 1975 with two piece rear main seal to a 350 SBC with one piece rear main seal which is 1986-up.
I was wondering if I should also change my TH-350 to a newer version?
What else is required?
Thanks to every hint and everybody.
Houman
Old 05-02-2005, 04:41 AM
302 Z28's Avatar
To my knowledge the older TH350 will work fine with the newer SBC. If the original TH350 is giving you hints that it is about to go south, I would keeep it. Of course if you already have a fresh TH350 then go ahead and change it.
Vince
Old 05-02-2005, 06:55 AM
MI2600's Avatar
Member# 3287
You'll need a one-piece flexplate.
Old 05-02-2005, 11:37 AM
Bumpstick's Avatar
Hammer and a torch
Think you mean a flexplate that has the "H" weight for the late model 1 piece seal engines...? (get a flexplate for the 87 and later 350)
Old 05-02-2005, 12:59 PM
Jeeps Are Us!
Thanks to everybody.
So the flexplate is different?
How about the converter? I'm going to get a TCI Streetfighter. Does it work?
Tks,
Houman
Old 05-02-2005, 02:28 PM
MI2600's Avatar
Member# 3287
The crank flanges are different and won't accept the older style plate. I believe it does have a kind of an H on it. Either will bolt up to your converter.
Old 05-02-2005, 11:18 PM
My transmission man recommends the use of a heavy-duty flex-plate on the one-piece Chevys. He said the stock ones have a habit of breaking.
how-to exchange the one piece rear main seal 59vette Engine 4 08-19-2004 12:48 PM
350 rear main seal??? Brian Morency Engine 9 06-09-2004 06:12 PM
Rear main seal shoe-horn bullheimer Hotrodding Basics 5 06-02-2004 03:14 PM
where to buy neoprene rear main seal armyaj33 Engine 2 04-29-2004 06:57 AM
Rear Oil Seal Replacement 71gtx Transmission - Rearend 2 03-09-2004 01:35 PM
