Question on sealing screws that mount the fuel sender to the tank. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-03-2012, 05:23 PM
I was looking for some coppper washers to seal the #10 screws on the fuel sender of my Studebaker fuel tank.
No luck at the local auto parts store. Not even when I told him that the make was Studebaker to make it easier to look up in the computer.
I found some brass ones, and thought they might be too hard and not seal.
Found some white nylon washers, and thought just right.
How well do these hold up to gasoline and gasohol?
I prefer not to use a liquid or moldable sealer, as I may need to adjust the fuel sender arm, which would require removal.
Old 07-03-2012, 05:41 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I did some googling and the concensus is that gas won't eat nylon. Unless this is on the bottom or side of tank, the washers won't see too much fuel anyways.
GM Fuel Tank Sender smokey626 Electrical 2 05-05-2012 03:19 PM
Fuel tank sender farmall_560 Electrical 6 07-19-2011 10:15 PM
Fuel Tank Sender.. requires earth? duncan_m Electrical 2 08-02-2008 12:02 AM
Fuel tank sender 53 chevy propaneburner Electrical 4 03-10-2008 04:09 PM
Fuel Tank Sealing JimmyL Engine 1 09-29-2003 05:08 PM
