Hotrodders Bulletin Board
#1
Question on swapping or not?
ok i have a 1968 chevy pickup with a 78 monte carlo 305 carbed with a cracked block. I found a 1989 camaro 305 Throttle body injectection
for $75 can i take the intake and carb off my 78 to fit the 89 or do i need to do something different.or could i make my old truck tbi and how do i go about doing it.Any help or comments would be much appreciated. I have about 900 bucks to spend......... thanks broc2451 |
#2
The intake from the earlier block will swap right on, but you`ll have to slot the 4 center bolt holes to line up with the 89`s heads since the angle was changed in 1987, a machine shop can do this for you rather easy. To keep the TBI means you`ll have to run a electric fuel pump with the correct pressure, plumb a fuel return line to the tank, get the computer and harness from the camaro donor, as well as run oxygen sensors, etc. the carb swap would be much cheaper.
Back to top |
Similar Threads for: "Question on swapping or not?"
| swapping rear ends, brake question..... | 69elcaminoss | Suspension - Brakes - Steering | 2 | 03-30-2004 10:26 PM |
| Swapping pump location question | Jag Daddy | Engine | 10 | 03-22-2004 11:36 PM |
| Hotrodders Guidelines -- READ ME | Jon | Suspension - Brakes - Steering | 0 | 06-14-2003 05:03 PM |
| Hotrodders Guidelines -- READ ME | Jon | Electrical | 0 | 06-14-2003 05:01 PM |
| Hotrodders Guidelines -- READ ME | Jon | Body - Exterior | 0 | 06-14-2003 05:00 PM |
