Question for those with vac pumps - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-18-2012, 11:19 PM
I am getting what I think is a lot of oil in my breather tank that my vac pump feeds to. How much oil should I be seeing in the tank? Originally the guy who installed the pickup for the pump in the valve cover had it down low on the side of the cover. Also the fitting was just a fuel cell fitting, so just a straight through hole. I thought the excess oil was from when the top end fills with oil. So I changed the pickup to the front of the valve cover, up as high as possible in the top corner. Also used a "bulkhead breather bolt" - not sure if thats the correct name but its basically a bolt type fitting that on the inside only has holes on three sides of the hex, so it should actually flow oil. I was expecting these changes to result in less oil in the breather tank, but its pretty much the same.
Old 12-19-2012, 07:55 AM
RWENUTS's Avatar
More info!!
What motor?
What exactly are you trying to achieve?
Old 12-19-2012, 08:08 AM
vinniekq2's Avatar
how much vacuum are you drawing?do you use a vacuum limiter?
Old 12-19-2012, 09:28 PM
Its a SBC and I'm running a vac pump for crankcase vacuum. It's drawing about 10". Just wondering why I have so much oil in my breather tank.
New guy vac question! luckynumberslevin Engine 5 07-10-2011 01:54 PM
idle problem and vac. question sickolds Engine 12 10-18-2010 04:11 PM
Another vac and timing question ? Fast 4 Door Engine 1 07-25-2010 07:50 AM
Crankcase Vac pumps on steet motor? 540neverdone Engine 3 06-14-2009 10:16 PM
Bendix Master Vac question APalusky Suspension - Brakes - Steering 2 11-19-2006 09:10 PM
