Question on using an sensor for turning on/off electric fans? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-29-2008, 10:03 AM
I have an electric sensor already in my intake manifold on my Chevy 350 for an electric temp gauge. Can I run a wire from this sensor to control an electric fan setup? I wasn't sure how the electric signal would be effected by running a second wire from it. I could always add a second sensor to control the fans I guess.
Old 02-29-2008, 10:16 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Joe,
That's the wrong type of sensor.
You'll need one that will turn your fans on & off at a predetermined temps. ie on at 210* off at 180*
Take care,
Rich
PS http://store.summitracing.com/egnsea...115+4294860934
Old 02-29-2008, 10:18 AM
Looking at the kits I saw in summit, the sensors looked pretty identical. An electric wire runs to a separate switch that does the "on at 200 off at 190" type control. I assumed that the sensor controls resistance through the wire to activate the on and off settings of the switch.
Old 02-29-2008, 10:23 AM
look at the bottom of the first page of the link I put there for summit.
Rich
And part #prf30110
Old 02-29-2008, 11:33 AM
Thanks for clearing that up for me. Makes a little more sense now!
Old 02-29-2008, 12:42 PM
I designed a little comparator circuit that parallels the existing temperature gauge. It's high impedance front end has no effenct on the gauge. It requires a relay however. If you have any electronics assembly skills, I could send the diagram to you.
Cam
Old 02-29-2008, 12:46 PM
IMHO, any thrmal fan switch required a relay. There are control modules that turn the fan off and on based on a thermally variable resistance, but that is different than a true switch. I believe most fan switches are simple reed switches activated by the temperature around them. These are a little too delicate to be consistently switching 30 amps off and on. Whatever you do, I strongly recommend a relay.
Pat
Old 02-29-2008, 12:50 PM
Cam, Could you send me the diagram to at least check out what you came up with? I know enough to be dangerous.
Pat, I agree with you on the relay. I have a handful of new bosch relays on hand. I've put them to good use upgrading most of the electrical items in my '70 Impala.
Electric fans not fanning when switched on lumberjacknooj Electrical 6 06-01-2007 02:13 AM
Best electric fans americanLT1 Engine 8 07-15-2005 12:44 PM
Electric fans Chopper64 Engine 9 05-17-2005 08:16 PM
Electric Fans VS Clutch Fan Jag Daddy Engine 18 04-25-2003 09:15 PM
Electric fuel pump question? HemmiGremmie Engine 2 03-23-2003 02:15 PM
