question on valve springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-12-2002, 05:40 PM
stfinney's Avatar
Post question on valve springs
If you have valve springs with a max lift of .500, what do they recommend for actual valve lift? Can you safely run .480 or .490? I am not that knowledgeable on head components, so any help would be great!!
Old 11-12-2002, 05:45 PM
BOBCRMAN@aol.com's Avatar
Post
yes, you can use the 480-490 lift if the springs are set up correctly, also check for clearance between retainer and guide top or seal top if you have positive seals
Old 11-12-2002, 06:00 PM
stfinney's Avatar
Post
I was just checking. The cam I have right now has .467 lift. I just wanted to make sure the springs would be ok before I had them installed.
[ November 12, 2002: Message edited by: stfinney ]</p>
