Question on where to pick up power for electric fan & headlights. - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-23-2012, 11:08 AM
Originally Posted by grobb284 View Post
II am thinking of adding the switched power of the headlight relay to be picked up from this same power lead for the coolant fan, ie. a power lead from the alternator to a second fused relay panel at the front of the vehicle, for the coolant fan and headlights. This would take a large load off the initial fuse panel.
Take your power off the "always hot" horn relay contact. That's where GM used to do it.
  #17 (permalink)
Old 08-24-2012, 01:55 PM
russ69coupe's Avatar
Last journal entry: starting to go the right direction
Funny, I was just reading this Catalog last night.
It is worth the read. Mark at MAD Electrical really knows his stuff.
hth,
Russ
  #18 (permalink)
Old 08-25-2012, 02:07 PM
JeffB's Avatar
There is something that a lot of folks miss and that is the use of relays when doing a rewire this explains it well: Custom Cars Classic Hotrods Streetrods-Watsons StreetWorks Here in the archives of hotrodders.com are many articles by the late Doc. Vette who helped me out a while back.Two places you never want to run without a relay is an electric fuel pump and an electric fan(these draw a large amp load),a common complaint with older cars is dim headlights even though they have been halogen upgraded.I added the relays as per the link and WOW! major lighting improvement!
  #19 (permalink)
Old 08-25-2012, 02:28 PM
I had put halogen bulbs in my '64 Corvette years ago and while it helped, it wasn't all that impressive.
About a month ago, I did the headlight relay conversion. I run a 1-wire alternator, so I hid the new headlight relays in the old voltage regulator casing. Note that in GM fashion, this taps off the horn relay that receives its current directly from the alternator.
Using the photometer in my Nikon, I estimate that this conversion made the low beams 100% brighter and the high beams 66% brighter. Others report similar increases. This also takes a load off of your dash lights and they too get brighter.
98 chevy 1500 pick up - huge loss of power Fast 4 Door Engine 3 10-31-2010 08:00 PM
no headlights, or power windows cdiedrick Electrical 2 07-25-2009 06:41 PM
1950 3100 headlights tech/question bill78honda General Rodding Tech 2 08-15-2008 10:26 PM
Power assist sreeing for 63'Ford pick-up Allan MacDonald Suspension - Brakes - Steering 1 03-18-2006 05:08 PM
7" Headlights Question ZipZ28 Electrical 3 04-17-2005 01:32 PM
