A question for you electric choke guys - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-30-2008, 09:01 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
PS There is no terminal on a Chevy starter that is switched on with just the key on.[/QUOTE]
I stand corrected on my post. When I had some down time today at work I remembered that connection on the starter was used to send power to the coil on the early "points" systems while cranking. I have been working the last 29 days straight and my memory has been a little foggy lately. Sorry for the miss information.
Stephen
  #17 (permalink)
Old 05-30-2008, 09:17 PM
SSedan64's Avatar
3-prong senders
I like the 2 & 3-prong oil pressure senders for choke & fuel pump relays. I also run a wire from the (R) terminal on the starter to the oil sender to activate the fuel pump relay a little sooner when cranking. Safety safety.
  #18 (permalink)
Old 06-01-2008, 10:07 PM
Thanks for all the replies it really helps So since the choke doesn't draw very much amperage I can hook it up to any 12volt ignition source. My next question is, where can I hook my electric fuel pump up to, the engine came with a mechanical one and I am unsure of what to tap into for power here.
Thanks again,
Keith
  #19 (permalink)
Old 06-02-2008, 01:36 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
If you want to use the oil pressure switch, its relatively easy. Of the single-connector switches, some switches are grounded when pressure is present, others are grounded when there is no pressure. They all look very similar. I did this exact thing for my electric fuel pump in my boat. I didn't want the pump dead-heading against my needle and seat when the engine wasn't running so I used a relay to a switch that grounds when pressure is present.
I sent switched power to one side of the relay's trigger coil, then grounded it at the pressure switch. Then battery voltage to the switched side and out to the pump. I also rigged up a manual switch to ground the relay if I want to prime the bowls at the beginning of the season.
You could do the same, but since its a tiny voltage you don't need to run a big 12v supply line. Just run switched 12v power to both of the "in" sides of the relay. Then out to the choke and ground the relay at the switch.
The easier way is to use a pressure switch with multiple connectors. They typically provide continuity (through the switch, not to ground) when pressure is present and you can skip the relay.
  #20 (permalink)
Old 06-02-2008, 02:41 AM
malc's Avatar
Living At The Speed Of Life
A relay is essential in wiring a fuel pump as well an oil pressure switch, mentioned above.
Relay,
Terminal 30 to battery with fuse
Terminal 87 to fuel pump
Terminal 86 to oil pressure switch
Terminal 85 to ground
A relay is used because the pump needs a full 12V feed.
  #21 (permalink)
Old 06-02-2008, 09:13 AM
Hey Keith
DocVette had several good posts describing a relay-triggered electric choke circuit that picked up a wire off teh alternator to trigger the relay. The idea was, if the engine wasn't running, the alternator would not be producing power, so the relay would not be triggered and the choke heater would not be powered-up". Wouldn't work with a one wire, I don't think, bu tif you check his posts in the electrical forum, I'm sure you'll get some more good input.
Pat
  #22 (permalink)
Old 06-02-2008, 05:04 PM
Thanks again guys. What kind of relay should I be looking for?? Where can I attain such a relay??
  #23 (permalink)
Old 06-02-2008, 05:46 PM
My 2 cents worth
Wiki Edits: 3
Most RV supply places have them with the connector that plugs on to it, or any parts house will surely have the relay in stock. It is a real commonly used Bosch relay.
So common I keep 10 in stock.
  #24 (permalink)
Old 06-02-2008, 07:53 PM
Jmark's Avatar
Lots of Bosch and "bosch style" relays on ebay one at a time or in bulk. Good to have a few around for projects.
clicky here.
Mark
  #25 (permalink)
Old 06-02-2008, 09:28 PM
SSedan64's Avatar
Relays
Another cheap place to get relays. Junkyard. You can get the whole relay blocks that are used to mount 3-5 relays in 1 spot. The FrontWheelDrive cars are a good place to scrounge. Usually have multiples in 1 block. Horn,Fuelpump,ACfan,Radfan,lights etc. The Toyotas have high quality relays, haven't had 1 go bad.
  #26 (permalink)
Old 06-02-2008, 10:18 PM
My 2 cents worth
Wiki Edits: 3
Two things you have to be careful of when doing this, is whether or not the relay is diode protected or not, and their specific wiring schematic. The universal Bosch relay can be wired with a ground trigger, or a positive trigger, and there are numerous sites on the web that that show both ways to trigger it.
One of my favorites is http://www.6066gmcguy.org/BoschRelay.htm
  #27 (permalink)
Old 06-02-2008, 10:26 PM
SSedan64's Avatar
Glad you add that info Carsavvy. I try to get mine from the older cars, but there getting crushed pretty fast. Great link BTW.
  #28 (permalink)
Old 06-03-2008, 12:28 PM
Here is a pic of my oil pressure sensor.
http://img.photobucket.com/albums/v7...essureunit.jpg
Since it is a 2 prong unit, how the **** do I hook up a realy to that. I am so confused these days haha all help appreciated as always!!
  #29 (permalink)
Old 06-03-2008, 01:29 PM
malc's Avatar
I think you´ll need a GM three terminal oil pressure switch.
  #30 (permalink)
Old 06-03-2008, 01:52 PM
SSedan64's Avatar
Have you checked this link from carsavvys earlier post?
How does an electric choke work? firewood Engine 18 06-19-2010 07:19 PM
Quadrajet electric choke. kegross1 Electrical 7 09-21-2009 08:01 AM
Manual or Electric Choke? 58Chev Engine 6 06-02-2006 07:00 AM
Electric Choke Conversion ? bigjoedo Engine 2 01-27-2003 07:17 PM
Carburetors, electric or manual choke? 66StangBoy Engine 5 11-07-2002 04:30 PM
